all-trac camry and all-trac celica... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2003, 08:23 PM   #1 (permalink)
View TubRog5's Photo Gallery
They both came out in the same year. So my question is: Is there any big difference in the suspension between the two? What about brakes? Any input would be grateful. Thanks..
TubRog5 is offline   Reply With Quote
Old 08-22-2003, 09:34 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
I would think the brakes and suspension would be the same as the non all-trac versions of the cars, so they should probably be different.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 08-23-2003, 07:12 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Huh? How can it be the same and different at the same time?
The suspension setup on the all-trac versions are different. Theres a rearend (differential, driveshaft, etc..) on the all-trac.
"Skoolin' the unlearned!"
Old 08-23-2003, 09:00 PM   #4 (permalink)
Crossdrilled and Slotted
View myconid's Photo Gallery
You've never been working on a car, and said, I worked on car a, and this is very much like car a, so it must be the same.. only to find out later it isn't? Stealth is just joking.. you'd THINK they would be the same.. its logical.. which is probably why they aren't the same.
myconid is offline   Reply With Quote
Old 08-23-2003, 09:23 PM   #5 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
in the gen 2 alltracs, were the engines mounted transversely? or just the same as they are in an FF gen 2??
jon
'92 Camry SE V6 5spd
jwa276 is offline   Reply With Quote
Old 08-23-2003, 10:46 PM   #6 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
Geez, these posts are confusing.
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 08-24-2003, 01:58 AM   #7 (permalink)
jon
Same as any other generation 2 camry.
But yes, sounds like they're totally different then. The all-trac has a different suspension from the fwd camry also correct? Well, I know the struts are different. The springs are probably the same, or closely. Shocks? I'll probably end up doing a celica suspension conversion. Aftermarket support will probably be better that way.
Old 08-24-2003, 02:45 AM   #8 (permalink)
Stealth's Avatar
Oh hmm.. Well I see how you found my post confusing, and I wasn't joking either. I was saying that the all-trac camry probably has the same suspension as the normal camry, and the all-trac turbo celica has the same as the normal celica. I was saying they were different as in the camry and celica have different suspension.
Old 09-02-2003, 11:00 AM   #9 (permalink)
View illGT4's Photo Gallery
The All-Trac suspension is different than the other ST18X series celca.
ST185
AW11
ST162
FZR600
illGT4 is offline   Reply With Quote
Old 09-02-2003, 11:36 AM   #10 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
what are you canadian?:lol
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 09-03-2003, 03:27 AM   #11 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
it KINDA makes sense... he doesnt mean a car, he means Car A, vs Car B
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-03-2003, 07:26 AM   #12 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
the Gen. 2 Camry's suspension is the same as the Camry All Trac...
the Gen. 5 Celica's suspension is the same as the All Trac Celica's suspension....
since the Gen.2 Camry's suspension's different from the Gen. 5 Celica, the All Trac Camry's suspension's different from the All Trac Celica's...
also brakes...
make sense now..?
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 09-03-2003, 10:07 AM   #13 (permalink)
No. The All-Trac's rear suspension is not shared. The spring rates alone are different.
CHris
ST185
AW11
ST162
FZR600
Old 09-03-2003, 11:48 AM   #14 (permalink)
jwa276's Avatar
someone aught to just buy an alltrac gen 2 camry and throw a 3sgte in it! ultimate sleeper!
jon
Old 09-03-2003, 05:20 PM   #15 (permalink)
Instead of the 5th generation celica, what bout the 4th generation celicas? I know they're probably totally different from camry's, but theres gotta be something there.
And illGT4 is right, the all trac vs the base models of the celicas are a lil different. In most cases though, I'm sure its almost a direct bolt on/swap.
