Air Conditioner Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2007, 08:09 PM   #1 (permalink)
View marniejc's Photo Gallery
hey there everyone! really need some help here. for the past two weeks my ac has been going hot and cold.the light flashes and if i pressed it, the air would come back on. Now i have no cold air at all. Im taking it to the mechanic tomorrow but dont want to get worked over.would rather try to fix it myself, any suggestions. please!!!!!
marniejc is offline   Reply With Quote
Old 09-06-2007, 11:21 PM   #2 (permalink)
View toyomoho's Photo Gallery
Go to the link below and see if you can download the the A/C info for this year of car. Note: some links may be dead but the Gen_3 works and this should be enough to get you started.
http://oregonstate.edu/~tongt/camry
Old 09-07-2007, 07:44 AM   #3 (permalink)
Thanks for the link, I couldn't find what a friend of mine was asking me for. They said because my ac controller was blinking and not working that I need to find out how to pull codes from it. They say that there should be a couple of buttons that I push and it should go into a diagnosis mode. Do you know what manual I can find that information in?
Old 09-08-2007, 05:44 PM   #4 (permalink)
View marc780's Photo Gallery
Year, mileage, engine?
Some possible problems you can check yourself:
-A/C compressor belt - is it loose or slipping?
-Have someone turn on the engine and work the a/c switch; while you listen to the compressor from underneath. You may be able to hear the compressor clutch click on and off. It should turn on and off with the switch and not on its own. If this is whats happening, shut off the engine and check the electrical connections to the compressor and the switch. they may be very dirty, corroded or loose.
-A remote possibility - ignition switch is worn - if you have problems with other electrical components that you didnt mention, this switch might be worn out
-evaporator or condensor assemblies are very dirty and need cleaning with low pressure air (30 or 40 psi). These parts look like miniature radiators and have fins like one too - that need air to pass through them to function. If they're very dirty - it could affect operation
-A/C system needs a recharge and is just a little low on refrigerant. i doubt you have a leak because your air still works sometimes.
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 06:44 AM
Recharging a 1993 Camry Air Conditioner calguy99 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-11-2006 10:04 PM
Air Conditioner Problem for 94 Toyota TK V6 boomerboy 89-95 Toyota Pickup/Hilux 3 07-24-2006 04:31 PM
Short air intake question rabinny Archived Corolla threads 55 11-25-2005 08:01 PM
1986 Tercel with Air conditioner problem armyjunk Tercel, Paseo, Starlet, and Sera Forum 0 06-11-2005 09:16 PM
