94 Camry p1 300 trbl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2007, 08:31 PM   #1 (permalink)
View tba3015637's Photo Gallery
94 camry 3.0 P1 300 code, dies when it gets warm, changed cam sensor, ignitor, 3 coil pack, temp sensor, still dying
tba3015637 is offline   Reply With Quote
Old 09-07-2007, 09:40 PM   #2 (permalink)
View toyomoho's Photo Gallery
P1300 Igniter circuit malfunction. If you changed the igniter check the wiring between the igniter and ECU.
Old 09-24-2007, 10:01 AM   #3 (permalink)
View marc780's Photo Gallery
Idle air control valve in the throttle body stuck shut? try cleaning it with carb cleaner or sea foam.
Old 10-18-2007, 04:22 PM   #4 (permalink)
so Mr tba3015367, if you're still there, what was the fix after all?
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
just test drove 94 camry bowlofturtle 3rd & 4th Generation (1992–1996 & 1997–2001) 12 09-17-2007 06:02 PM
'94 Camry door ???'s Big Twin HD 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-05-2007 01:03 AM
94 camry xle jojopell 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-09-2004 02:43 PM
