Steering Problems!!!Please help!
Ok! i have a 94 camry le
The problem is after i change the four tokico struts and intrax lowering spring and install a strut bar!
Now when i turned my steering wheel to left end, i will hear a "thung" sound before come to the end. After i turned the steering wheel back to the center again i will hear another "thung" sound.
Then the whole alignment will pull to the left while im driving. If i wanna to pull it back to the center, i will have to stop the car to turn it to the right end and turn it back again. i will also hear a "thung" sound while i m turning to the right side.
another problem is when i go thru some rough surface road, i will hear some clanging sound ( if i switch down my window, can;t hear in the car). Sound like something is loosen.
This problem came to me b4 the alignment, after the alignment it still acts the same way.
So can anyone tell me what's the problem? Please thank you everyone!
