Originally posted by gqdabien
What are the valve seals? Is it like a gasket btw the valve cover and head?
The gasket between the valve cover and head is called a vavle cover gasket.
The valve seals are inside the head underneath the valve springs. Its not a diy job unless you have the right tools and know what your doing.
The seals are made out of rubber so as time goes on they get hard, brittle, and don't seal like they should.
When the engine cools off the seals shrink and let a little bit of oil (few drops) drip pass the valve into the combustion chamber. Thats why you see white / blue smoke on startup after the car has been sitting around.
When the engine is warm / hot the seals expand and seal up. Thats why you don't see white / blue smoke after startup or when driving around.
How much would it cost ot fix?
I was quoted $650 by a Toyota dealership to replace the valve seals on my 3S-FE.
The parts themselves (the seals) are around $120. I was going to replace the seals myself, but never bothered with it.
