the gen 1 has been having a rough idle when stopped at lights lately. rough enough that the hood shakes up and down about 1" to 1 1/2". the oil was changed about 600 mi. ago, and it only occours when in drive. as soon as the shift to N is made, everything smooths out.
check plugs and wires cap and rotor, something is faulty might be plugs are too old and not firing or a wire might just be loose. it only does it at idle because the intensity of the spark is less so it is easier to miss.
Check your motor mounts. The front and rear could be busted causing excessive engine movement at idle.
Frito: The sparkplugs are screwed into the head on a gen 2. To access them you need to remove the sparkplug wires, just pull up on the boot (don't yank on it by the wire).
Then you use a 3/8" drive rachet, 3/8" drive extension (6" long will do), and a 5/8" sparkplug socket.
Originally posted by idrivemyself any recomends on which plugs to pick up? i've heard that Denso's are TRD's top plug, this would imply that i should get a set for my camry!
Denso or NGK.
Either one will work just fine. Just make sure you gap them properly.
