CV boot replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2003, 11:54 PM   #1 (permalink)
View bboylanky's Photo Gallery
CV boot replacement
Is it possible to remove the outboard joint on the driveaxle (front right side)??
bboylanky is offline   Reply With Quote
Old 08-26-2003, 11:58 PM   #2 (permalink)
on a 1990 toyota camry LE V6 that is.....
thx
Old 08-27-2003, 12:36 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need to unbolt the axle from the hub.
1. Remove cotter pin and castle nut.
2. Remove 30mm nut holding axle to hub.
3. Remove strut to knuckle bolts and nuts. These mofos are torqued on, so use a breaker bar or impact wrench.
4. Remove axle from hub.
"Skoolin' the unlearned!"
Old 08-27-2003, 01:09 AM   #4 (permalink)
I should've mentioned where I'm at. I'm at the point where I have the driveaxle in my hand. I can't seem to find a way to remove the outboard joint to get the boot off so I can put the new one on.
