Transmission flush? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2007, 07:22 PM   #1 (permalink)
View Monkey123's Photo Gallery
Transmission flush?
I have a 1992 Camry and I want to flush my transmission fluid. There are two cooling lines.
Which one is the return line, the left or the right? Do I need to plug off where the line connects to the radiator? Thanks for the help.
Monkey123
Monkey123 is offline   Reply With Quote
Old 09-25-2007, 07:54 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
On my 2000 Camry, the output from the transmission to the radiator was the passenger side hose. So the driver side one would be the fluid returning to the transmission.
2007 Camry 2.4L 5M
Old 09-26-2007, 08:23 PM   #3 (permalink)
Did my transmission flush today and the car shift softer or smoother than before. I did not
know which hose is the return hose. I went ahead and did the trial and error method. I took the left hose out and started the car. The engine did not sound right and I smell burn on the engine or transmission. Turned off the engine right away and put back the left hose. Took out the right hose and started the car, engine sound great and fluid pump out from the right side hose. Did follow the DIY transmission on this website and took about 6 quarts of Castrol ATF at Autozone for $4.00 each. Thanks for everyone help.
Monkey 123
tranny dipstick? karosR6 2nd Generation (2005+) 18 04-11-2009 03:01 AM
Whirring transmission afviper Previa Forum 18 06-05-2008 10:02 PM
grinding, is it the transmission? jcarter 1st Generation (1998-2003) 2 05-22-2007 01:45 AM
Transmission Flush on Gen 5 johnnyzee 5th & 6th Generation (2002-2006 & 2007-2011) 14 10-11-2005 09:23 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
