I need info on changing cv axel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2003, 02:42 PM   #1 (permalink)
View irishpilot's Photo Gallery
Please!!!
I need some info on swapping both axels on a 90' camry
I think it is the dx model.
I understand the need to remove brake calipers and swing the susp stuff out of way.
1.But I really want to know if it is as easy as pulling the axel out and puting new ones in.
2. what side should I start with?
thanks
any info greatly appreciated, must start very soon...........
irishpilot is offline   Reply With Quote
Old 09-01-2003, 03:22 PM   #2 (permalink)
anyone??
Old 09-01-2003, 04:50 PM   #3 (permalink)
Oomp loompa doopidy doo..
spills1969's Avatar
View spills1969's Photo Gallery
Well, the hard part is getting the strut outta they way. First take jack the front end, or the whole car, onto jackstands. remove whatever wheel on the side you are working on. then take off the calipers and the "pad holder". If my emory serveds me right, u shud be able to remove the rotor. then its just a matter of removing the right suspension parts so that you can pull out the axle.
The hard part of this is all the crap u gotta get outta the way to get it off. IF u got a 4 Cyl, u shud have like 6-8 nuts on the end of the axel that goes into the transmission. Thats all u gotta do to take that end off. Just be careful when you put everything back in. I put mine in a little wierd into the wheel bearing which meant that i had to get a new wheel bearing put in, and I cudnt do it cuz it has to be pressed in. But your best bet ie to get a Haynes Manual. I went by that and it never leads me wrong, unles u gotta rebuild your engine. Found that one ou tthe hard way! Good luck!
http://www.cardomain.com/id/manwhorecamry
Nitrous is like a hot woman with STDs. You wanna hit it, but you're scared of the consequences...
spills1969 is offline   Reply With Quote
