Got new lights how do i install? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2003, 01:11 AM   #1 (permalink)
Senior Member
View Lychee's Photo Gallery
Question Got new lights how do i install?
I just got back from toronto and i just bought new xenon bulbs for my gen 4 camry. how do i install them?
1998 Camry LE -- Black
Mods -Osram Silverstars -14inch Alloy wheels -Short ram intake
2001 Camry XLE -- Silver Bone stock
Lychee is offline   Reply With Quote
Old 09-03-2003, 01:25 AM   #2 (permalink)
A work in progress...
View Mokkema's Photo Gallery
if you just got bulbs its very easy. I hope your talkin about just xenon bulbs and not a full HID conversion kit...but hopefully this is what ur lookin for.
Pop your hood, and in the back of each headlight assembly you will see a harness attatched to the bulb going into the headlight assembly. Simply twist the bulb to unlock it from the assembly and place new bulb into socket like a plug. Then insert the new bulb back into the assembly just like you took it out, and voila, you have new headlights. Hope that helped.
mike
99 Mitsubishi Eclipse GS-T
Pioneer DEH-8400MP
2xInfinity Kappa 692.5i
2xInfinity Kappa 63.5i
US Acoustic 340W Amp
95 Toyota Camry 5S-FE - SOLD..I'll miss her
Mokkema is offline   Reply With Quote
Old 09-03-2003, 03:22 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
if you dont know how to change a headlight bulb, you should be smacked
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-03-2003, 07:32 AM   #4 (permalink)
Senior Member
k well the back of my light i found the harness but it's connected to the lightbulb inside a rubber boot. inside there is also a clip that clips down the lightbulb between the bulb and the rubber boot which is screwed down to the reflector housing
Old 09-03-2003, 02:03 PM   #5 (permalink)
you don't need to take off that little pin holding the housing together (besides its held by glue as well) just turn the lightbulb til it is free to come out...its simple a turn and lock mechanism.
Pioneer DEH-8400MP
Old 09-03-2003, 02:19 PM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Wierd... this question has come up twice in the past week or so
Go to the back of the headlight, find the wires, follow them to the harness/socket, turn the socket 1/4 turn counter clock wise (the only way it will turn) and pull it out.
There is a tab you need to press to get the bulb off the harness.
The only thing you shouldn't do is touch the glass of the bulb. Your skin oils could make it shatter when it heats up.
If you already have touched it, wash it off with water, a paper towel and a tiny drop of dish soap.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 09-03-2003, 02:32 PM   #7 (permalink)
Senior Member
Are you guys talking about the gen 3 lights or gen 4's cuz they use different lights. The gen3's have 2 bulbs one for low beam and one for high beam. The gen 4's not gen 4.5 use the H4 lights.
I have the gen3 camry manual and it doesn't look the same
Old 09-03-2003, 02:59 PM   #8 (permalink)
View tinman831's Photo Gallery
ok youre gonna have to take out that screw holding down that metal clip. remove the metal clip that holds it down to the housing. once you take out the clip, twist it and both the harness and the bulb should come out.
tinman831 is offline   Reply With Quote
Old 09-03-2003, 04:36 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
dont wash a lightbulb with water, use either distilled water, or rubbing alcohol.
Dave Zoni
Old 09-03-2003, 05:51 PM   #10 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
hey lychee.. u figure it out yet? I also have an early gen 4 camry and i was trying to see if i could take out the lights.. but no success.. mayb if u figured it out u could explain it to me?
I dind't wanna be rough with the parts so i didn't twist too hard.. am i supposed to use alot of force or should it be fairly easy to twist.
KerTiZ is offline   Reply With Quote
Old 09-03-2003, 06:01 PM   #11 (permalink)
Senior Member
i've been busy and i think i'll get some time tonight to tinker around i'll post if i figure it out, so far i've heard that you twist after you take all the shit out but my friend has a civic which has h4's and the mounthing system sounds the same as the cam and he says you just pull the harness straight out so i'll try both ways and post when i get everything done
Old 09-03-2003, 06:08 PM   #12 (permalink)
View Tubbyc's Photo Gallery
you don't need to remove any screw, if you have the owner's manual it should tell you how.
I had a gen4 camry before.it uses H4 bulb, hope you get the right one, unless you have a gen 4.5 camry...
this is how you change the headlight
1. Unplug the connector (pull on it, not twisting it), and remove the rubber cover (just pull it off)
2. Release the bulb retaining spring, take out the bulb and put in the new one
(NO twisting required, the spring held the bulb there)
3. Reinstall the rubber cover, connect the connector..
People!! he has a H4 bulb, stop telling him to twist the bulb .. that's for gen 4.5 9006 or 9005 bulb
Tubbyc is offline   Reply With Quote
Old 09-03-2003, 06:14 PM   #13 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Isopropal Alch. ... f-dish soap!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 09-03-2003, 06:20 PM   #14 (permalink)
Toyota Lover
KerTiZ's Avatar
0_o !!!
nice.. thnx Tubbyc
Outta curiosity.. did u ever put silverstars in your gen4? if so.. which ones?...hehehe
Old 09-03-2003, 06:34 PM   #15 (permalink)
yo i have 3 toyota's
aladdin102's Avatar
View aladdin102's Photo Gallery
dave how do u change the headlights?? hahaha j/k dood i just put my silverstars in
aladdin102 is offline   Reply With Quote
