A/C air flow problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2007, 10:00 PM   #1 (permalink)
View buytamil's Photo Gallery
Model : 2003 Camry LE 52K
My A/C is working fine, but when I change the air flow to floor, the air comes through the defroster and no air at the back also. what is the problem and how can I fix it. Is there anything I can check and correct it.
buytamil is offline   Reply With Quote
Old 10-09-2007, 06:36 PM   #2 (permalink)
View toyomoho's Photo Gallery
The airflow is controlled by a series of doors via small DC motors or vacuum power. You will need to determine if the problem is the switch, wiring or motor. The motors are under the dash in various locations, the switch can most likely be accessed from the front of the dash by taking it apart.
You can attempt to download the service manual info at the link below; this will provide much more detail. A word of caution is these links may not always work.
http://www.camrymanuals.com/
Old 10-10-2007, 06:57 AM   #3 (permalink)
Thanks for the Info. Let me try today.
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 06:44 AM
another a/c problem, but not like the others bigtrucknwheels 89-95 Toyota Pickup/Hilux 5 06-04-2007 02:40 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
