Originally posted by eecc
can any1 explain what/how each of above improve the ignition?
MSD 6A: The amplifier box. This is what gives you a stronger spark.
MSD blaster ss coil: You can use the stock coil or go with a aftermarket one. I choice to go with a aftermarket coil. I also choice the blaster ss coil over the blaster 2 or blaster 3 cos the blaster ss is more efficient and can be mounted in any position.
MSD tach adapter (8910-HEI): You need this part for Toyota's otherwise the MSD won't work.
