The purpose of the PCV ventilation system is to reduce condensation in the crankcase and reduce the amount of vapor and gases emitted to the atmosphere.For each gallon of fuel consumed, one gallon of water vapor is created through condensation. Un-less
the crankcase ventilation system is functioning properly, a deterioration of the oil will occur, thus promoting premature engine wear. The PCV system is a sealed system. Air leaks can disrupt the system’s
flow, resulting in a pressurization of the crankcase, forcing oil and vapor back into the air cleaner via the fresh air inlet. The PCV valve is a calibrated vacuum
leak; an improperly calibrated valve can result in a surge, rough idle, or a lean misfire condition. In the absence of low pressure in the crankcase, due to a
defective or plugged PCV valve, the venturi effect of the air moving through the air horn can result in a siphoning effect. When this occurs, oil can be pulled from a valve cover through the fresh air inlet, contami-nating the PCV breather filter and air filter element.
When the filter is oily, the PCV valve and the entire crank-case ventilation system should be examined. A re-striction
can result in some costly engine damage.
