Vogtland Lowering Springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2003, 11:34 PM   #1 (permalink)
Ride it like a Llama
miken517's Avatar
View miken517's Photo Gallery
hey i was just on ebay, and i found these springs i think some of you might be interested in Vogtland Lowering Springs Camry 92 to 96.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430466317
i hope this helps.
-'95 LE Dark Green.
-16" Motegi Gunmetal MR7's.
-OBX Muffler.
-Car PC in the Workz
miken517 is offline   Reply With Quote
Old 10-28-2003, 04:49 PM   #2 (permalink)
View luisitol's Photo Gallery
Has anyone used Vogtland Lowering springs? if so whats the verdict? Godd ride? How stiff? even drop? I hear its a 1.5" drop, seems pretty good drop.
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 10-30-2003, 12:17 PM   #3 (permalink)
Anyone have these springs on a Gen 3??? I really need to hear some feedback, thank you
Old 10-30-2003, 02:15 PM   #4 (permalink)
miken517's Avatar
Hey
http://www.toyotanation.com/search.p...der=descending hope this helps!
I would personally buy them if i didn't have my springs.
-'95 LE Dark Green.
-OBX Muffler.
Old 10-30-2003, 03:15 PM   #5 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I've got a gen3 i4 on Vogtlands.
They're a dream. Great ride. Could stand to be a little stiffer for my taste but hey I also drive a 76 vette with a fiberglass mono leaf in the rear so comfort isn't an issue with me. Tho on the camry you feel as if you're on slightly firmer stock springs with solid aftermarket struts until you throw it into a turn, then its rock solid! They're made of a newer metal so they won't sag over time either and they're designed for sound systems... meaning they are a tad higher in the rear so when you put your subs in it won't look all saggy.
btw- they're not a 1.5" drop, its more like 1.7" and they only make one type for camrys, so you'll need to chop 1 full coil off for the i4.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 10-30-2003, 04:03 PM   #6 (permalink)
Thanx blue...did you chopit off yourself or did you have a shop do it? If it was a shop, how much did they charge you?
Old 10-30-2003, 04:15 PM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
I did it using a dremel tool with a high speed woven cutting disc for metal.
Old 10-30-2003, 04:18 PM   #8 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
GET A DAMN HACJKSAW NO SKILL REQUIRED!!! HAH HA!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 10-30-2003, 04:21 PM   #9 (permalink)
yea i have a dremel and a round sawtype blade i bought to cut metals, i use it mostlye to cut through thick aluminum but i think it'll cut through the springs. Any pics of how much to cut off?
Old 10-30-2003, 05:23 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
The large fiberglass or kevlar woven ones work the best. I measured from the top where the spring seems to be cut already (NOT the tightly wound end where the last coil is milled horizontally flat) and went straight down. One full coil. Of course i went 1/4 coil by 1/4 coil reinstalling them each time to get it correct.
You'll prolly want to get a camber kit too.
