Originally Posted by fisherman81
I have a camry v6 that idles rough and lost acceleration but runs fine once underway, the weird thing is if the aircleaner is unlatched it runs ok. I cleaned the mafs and changed the fuel filter but still the problem exsist. could it be a bad mafs , no engine code has showed up ?
Jeff
I got my ass handed to me by a car that did the same thing.
The air filter was perfectly clean but when I removed it the car ran fine. It turns out that it was a cheap air filter and the paper part of the filter wouldn't flow hardly any air. The car would not idle well and would frequently stall at idle.
I replaced the air filter and it worked perfectly. Believe it or not, that's the truth.
I highly doubt that it's your problem also, but it's worth checking into.
EDIT: By the way. I would not submerge your throttle body in carb cleaner as recommended above. Only use a specified throttle body cleaner to clean it so that it does not get damaged. Also, the throttle "flap hinges" are actually called the throttle plate and throttle shaft.
