Need Audio wiring help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2003, 10:44 PM   #1 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
Hey.. i just got a new deck for my camry(97) and when i took out the old tape deck it required me to use a different connector for the new deck. Because of that.. i have to re-wire it.. but i've ran into a few difficulties... i can't tell which wires do what... eg) i can't tell which wires are for speakers or which is ground.. etc...
any help would be appreicated..
KerTiZ is offline   Reply With Quote
Old 09-10-2003, 10:50 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Do a
I've seen the wiring diagram posted up numerious times, so it should be easy to find.
Take alook at the thread below:
http://www.toyotanation.com/showthre...threadid=15196
"Skoolin' the unlearned!"
Old 09-11-2003, 01:55 AM   #3 (permalink)
View Axl Rose's Photo Gallery
DIY easy
ok, you can try to find out what wires are what
but to learn their purpose and eliminate risk that some cars may have differences (remember your basing it on color), here is what you
Cut all the wires so they are free at the plug end
With the car OFF, get a multimeter
Ground the multimeter to your chassis
Now touch the positive from the MM on all the wires (try the fattest two first, probably white / red)
ONE wire will display a charge on the MM
Therefore, this wire has a completed circuit from battery to plug to multimeter to negative chassis with the battery off
This wire is therefore the POSITIVE
Now, turn your ignition to accessories
The accersories board will emit power only when the car is on or past accesseories, it is this cable that makes your radio turn on with the ignition
Now do the same as before, except now there wil be 2 wires that give charge (the one from before plus a new one)
The new one is the ACCESSORIES cable
Now with the positive end of the multimeter on the positive wire, touch the negative end to all the wires (other than acc and pos) until you get a current
This has completed a circuit from battery to plug to cable to battery
This means the one you just earthed to (probably black) is the NEGATIVE
From now on, you just have speaker wire plus antenna
antenna is fat and obvious
For speaker wire, just follow it
Or, with your head unit on (acc, pos, gnd) just touch any Positive/negative speaker combination with the output pos/-ve and a speaker will play, then u know whichj speaker is which
Remember, when dealing with 2 wires, pos and -ve, the pos will normally have a white/red stripe, as opposed to the flat -ve
Okay, i know its easier to just get a diagram, but if u want to know how to do it properly, there you go
Gen 2 '91
JBL GTO601.1
2 Pioneer 12"s
Response 4x50 WRMS
Power Accoustik Splits
Pioneer 6x9's
Lukey Headers and 2.25 Sports
5 Spd Manual
Axl Rose is offline   Reply With Quote
Old 09-11-2003, 03:54 AM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
woah there settle down noob.
haha just kidding, nice info, but its a lot easier to just look at the diagram. most toyotas are the same and will follow that diagram. i found that all the colors were pretty much the same on my girls 2001 celica gts as on my 94 and 92 camrys
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
