Axel replacement!!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2003, 08:40 PM   #1 (permalink)
View toyota4life's Photo Gallery
Exclamation Axel replacement!!!!!!!!
hey i'm need some instruction on how to replace the right axel on a 94 4cyl camry. The axel is still in the car i'm not sure how to get it out of the bracket that it goes though.
help if ya can, if u need more info let me know
toyota4life is offline   Reply With Quote
Old 09-11-2003, 11:14 PM   #2 (permalink)
View CamryDX's Photo Gallery
Do you know if it is a Bolt on or a Spline, Mine was a Spline and Get a bar about 6 feet long, if its a spline, and just pry from under the hood and it should pop out with ease, and to get it back in, set it into place, and hold it straight as you can, and put a wooden block on the end of the axel and pound it in as gentle as you can so you dont jar the CV joints
Jeff
1991 Camry DX
CamryDX is offline   Reply With Quote
Old 09-12-2003, 05:57 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Unbolt the wheel.
2. Remove cotter pin, castle nut, and nut (30mm) holding axle to hub.
3. Unbolt brake line and abs line (if you have abs) from strut.
4. Remove the 2 strut to knuckle bolts & nuts.
5. Seperate the strut from the knuckle and remove the axle.
6. Loosening up the retaining bolt on the center bearing (axle goes through it) and remove the big retaining ring (big ol c clip).
7. Remove axle from differential.
"Skoolin' the unlearned!"
Old 09-12-2003, 07:06 AM   #4 (permalink)
if you remove strut you have to get it aligned, you can just remove the ball joint and pulldown that sway bar and just let it hang freely
Jeff
1991 Camry DX
Old 09-12-2003, 07:53 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Even if you remove the tierod from the knuckle I don't think theres enough movement (left & right) in the knuckle to remove the axle.
The swaybar is not an issue if you jack up the front end of the car. With the entire front end off the ground the swaybar is unloaded.
I've always removed the strut to knuckle bolts & nuts when removing a axle on a 5S-FE. My 3S-FE is a different story since the axles bolt onto the differential instead of popping in.
Old 09-12-2003, 04:11 PM   #6 (permalink)
yeah duh, i didn't even think of that,
Jeff
1991 Camry DX
