Motor Mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2003, 12:08 PM   #1 (permalink)
(¬_¬)...
View Bensa's Photo Gallery
Motor Mounts
Just wondering if anybody needed their's replaced?
I took mine to T-Lex the other day because my Gen 3 was leaking some fluids... wasn't sure if was Tranny, Engine or Coolant (well wasn't any of the three) turns out it front engine shock.
The car has 154K on it and is a 94 V6...
Vibrations haven't been felt yet but fluid is still leaking outta the damn thing... anybody else have this problem?
It's a $101.50 part according to Basil.
Bensa is offline   Reply With Quote
Old 09-13-2003, 05:12 PM   #2 (permalink)
Current title:
View Ikon's Photo Gallery
hrm never knew the engine mounts had fluid??
Are u sure its none of the other fluids? If its only water it could be from the a/c. Id say check the fluid thats leaking see if you can identify it. Before having your engine mounts replaced.
Gen-3 Coupe '95 1MZ-FE
Custom Ram Intake w/K&N Filter
H & R Springs, Strut Bar,
Denso Plugs, Crappy 6 Spoke 16" Nissan rims w/kumho rubber (i got um for free ok?)
TRD Supercharger, Custom exhaust coming soon..maybe..hopefully..someone got some extra loot?
Ikon is offline   Reply With Quote
Old 09-14-2003, 03:09 PM   #3 (permalink)
(¬_¬)...
It's definitely the engine mount shock... had it up on the hoist and the fluid was kidna green?
wasn't anything else cuz I had all fluids changed and nothing was leaking.
Old 09-14-2003, 03:22 PM   #4 (permalink)
Current title:
Im almost positive that your engine mounts contain no fluid. They're just brackets and insulators with some bolts. I don't quite understand the whole engine mount shock deal either? If it's green fluid it should be coolant. But don't hold me to it I haven't seen you're engine bay plus I'm only an enthusiast not a mechanic.
Anyone else got some advice?
Old 09-14-2003, 04:50 PM   #5 (permalink)
(¬_¬)...
Put your car on the hoist and you'll understand what I talking about
I was scratching my head to what fluid was leaking myself... I believe I have Toyota OEM Coolant so it's red... and the ohter fluids are kinda orange/brown so was really puzzled at what was going on... car drives fine though so I ain't worried about it too much.
I'll probably get it done before winter rolls around as I'll be driving that one primarily instead of my other car.
Old 09-14-2003, 11:01 PM   #6 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
"front engine shock" - Never heard of such a thing. Where exactly is it located
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 09-14-2003, 11:13 PM   #7 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
guys, this "SHOCK", is the mount that is on an auto tranny equipped v6 engine from 92-96. It looks just like a strut. There could pissibly be fluid in it... im not sure. but definitely not enough to leak out. Green fluid is coolant. Find out where the leak is for sure, and fix it! If this strut were to blow out, it would most likely do so while driving and wouldnt leak gradually, and if so, it would yield about enough fluid to fill half a soda can. not a big trouble......... this engine mount strut is designed to control rotational flex from the engine, it really shouldnt blow... get a second opinion. I had one on my old camry, 92 with 206K miles on it and the mount wasnt blown...so in this case, i would say if it were truly blown, there is a bigger cause that you should investigate.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-14-2003, 11:19 PM   #8 (permalink)
I'm a Mac
zoni's Avatar
heres a pic... remember, gen 3 v6 auto tranny only...
Dave Zoni
Old 09-15-2003, 09:27 AM   #9 (permalink)
Current title:
Isn't that a cute strut never knew it was there..shame on me..I got a gen3 v6 auto too...
100 bucks for that little crudder? Dayam leave it be~!
Old 09-15-2003, 05:49 PM   #10 (permalink)
(¬_¬)...
Yup I ain't touching the bugger... the leaking has subsided guess it's all outta fluid!
car still drives really smooth so guess it's that stupid mount. That and we had it up on the hoist and it was clearly coming from that stupid mount... had the entire bottom end of the engine shampoo so it was squeeky clean a few days before I noticed more fluid leaking.....
I'm relieved to find out where the problem came from and I know it's not coolant. toyota coolant is red. tht and this fluid was slipery... coolant smells funny and u'll know it when driving cuz it'll stink big time!
I might replace it with a solid piece from a Gen4 if it fits... or just leave it be .
Old 09-15-2003, 11:45 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
MOST coolant on the market today is green... toyota coolant may be red, but who in their right mind would pay for that crap when its no different than normal stuff...
it only smells when it leaks if it leaks on the engine and it burns...
it does have a little slipperyness to it... not much just just a little... i would imagine the fluid in the mount is VERY thick... most likely much thicker than ever motor oil.
Dave Zoni
Old 09-16-2003, 12:13 AM   #12 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
One of the things I learned from talking to several toyota dealers over between LA and Sac is that Gen 3 Camrys (especially 5SFE models) tend to need the hydraulic (Front) and Torque (Bone) mounts replaced since the engine and tranny tend to vibrate slightly more when expected when going into overdrive.
I've bought the replacements ($42 for the Bone mount, $130 for the hydraulic). Once I put them in, I'll update if the vibration I get when accelerating stops.
One other side effect of it, the axle/driveshaft tends to warp if the mounts are bad enough for the engine to sway slightly.
The easiest way to determine if you have the problem (I've found) is if the car vibrates heavily between 65 and 75 mph (when it goes into overdrive). If you look at the bone mount, and its cracked, more than likely the hydraulic mount needs to be replaced.
Let me know if I left something out, or need to make a correction. I learned about this from experience, talking with parts counter guys/mechanics, and guestimating.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 09-16-2003, 12:53 AM   #13 (permalink)
I'm a Mac
zoni's Avatar
sounds good noob!!!!!!!!! FINALLY a NOOB that knows his shit!!!!!!! YES!!! victory! sorry, ive had a few bud lights this evening. i feel pleased to welcome you to the toyota nation community. and please remember to use the search function. all the noobs dont do it. i know you wont ask stupid questions tho, you are SUPERNOOB!!! haha. again, i apologize. i hope to get to know you, IM me on AIM at zonicamry
Dave Zoni
