Aging Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2007, 08:34 AM   #1 (permalink)
View Gerry Storm's Photo Gallery
Aging Camry
I have a 1986 LE which I have owned for over 7 years. It currently has 152K and is in generally fine condition. However, it is plagued by an unpredictable neutral start switch problem. The shift mechanism (auto) seems to be getting looser as well. I read in the manual that alignment of the shaft is critical. Sometimes when it won't fire I can lift the hood and jiggle the various wires near the starter and apparently cause the switch to engage...A new switch costs around $175 and I will likely wind up buying one soon but I still wonder if the problem could be in the loose shift assembly. Would appreciate any input from others with knowledge of this problem and potential solutions. Thanks.
Gerry Storm is offline   Reply With Quote
Old 11-10-2007, 09:19 AM   #2 (permalink)
View marc780's Photo Gallery
Id get a switch at the junkyard! For a fraction of new. Same goes for the shifter mechanism, first you have to figure out how to remove it so you can do it fast at the (pick a part) junkyard, probably just rip out the console or crawl under and unbolt it.
2008 Camry vs Accord vs Passat, showroom impressions (long) woodman411 5th & 6th Generation (2002-2006 & 2007-2011) 50 09-22-2007 06:03 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Toyota Camry Stereo Information '83-'00 AllMadd Camry & Solara Lounge 2 08-09-2007 08:11 AM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
