The 2004 camry I have is a lemon, I drive it to work everyday, put 12k mile on it per year. Right after the 3 years, 36 thousand miles, The tires could not pass the virginia safety inspection. The battery went dead on the road on a hot day in the summer 2007 on little river turnpike and could not be jump started. The worst happened yesterday evening that the gas pedal had no response at all. It was tolled to the dealership and I was told that I have to spend over $700 to replace the accelaration pedal assembly. during the year I had to add coolant ... I had a 1999Honda Accord and it did have any problem before 70k miles.
I would call Toyota corporate at 1-800-331-4331 and speak to customer service. Ask for some goodwill assistance on getting this repair covered. You might have a chance, if you are still really close to 3 years and 36,000 miles.
So what if you had to add coolant. Water evaporates over 3 years.
You've had one actual mechanical problem and you joined a forum to gripe about it?
I feel so sorry for you.
I was going to post that. It's not Toyota's fault you need new tires, and 36K miles is a decent amount of tread life. Batteries don't last forever, and you should have your coolant system flushed anyways.
that amount is too high, i wouldnt pay it, if they want to charge you that much it means more than half is labor, way more. Just buy the part, i bet it is a snap to put on yourself. You could even get it from a junkyard if you had to. Im guessing its Attached to or near the throttle body no doubt, you dont even have to crawl on the ground or anything.
The link is for the camry manuals, from this site (they are linked in the stickys in "General camry forum). I didnt see a part called "throttle assembly" in the exploded drawings but it is there, i'd just buy the part and you can figure it out where it goes.
In the schematic there is a device called "throttle position sensor" (left center of above image). Is that actually what they say you have to replace? No big deal, just change it out.
even if you had to replace the whole throttle body (not likely on a car with this low mileage) it wouldnt cost $700. http://www.camrymanuals.com/manuals/...rol_System.pdf
You're way off base, AGAIN.
He needs an accelerator pedal assembly. It's not in the engine compartment. It's on the floor and you push on it with your right foot to bring the RPM's up.
I contacted Toyota Customer Service. They are going to pay the $400 part. I pay $250 labor. That's good enough for me. Thanks a lot to everyone for the information!! I appreciate quick responses from Toyota CS and reps at the Alexandria dealership. It is the the acceleartor pedal assembly.
That was extremely nice of Toyota to do. Chalk up another one for Toyota...after all, they didn't have to cover anything at all.
