CEL oxygen sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2003, 11:20 PM   #1 (permalink)
View Harrier04's Photo Gallery
CEL oxygen sensor
My dad's camry got a CEL and the shop says the oxygen sensor is broken. They are asking 600 (for parts only) to replace both oxygen sensors. Shouldn't the CEL indicate which sensor is broken? Also how much should 2 new sensors cost? Thanks experts.
Harrier04 is offline   Reply With Quote
Old 09-17-2003, 12:51 AM   #2 (permalink)
View fe519's Photo Gallery
each sensor should not run more than $150 each and is really easy to change
fe519 is offline   Reply With Quote
Old 09-17-2003, 03:16 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: CEL oxygen sensor
Yup.
You need a OBD-II scanner to retrieve the codes though. Some autoparts stores do it for free.
"Skoolin' the unlearned!"
Old 09-17-2003, 09:41 AM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
youshould always use OEM O2sensor, becuz 90% of the aftermarket o2 sensor fails the emission test. and your's is roughly $300 a piece becuz its probably a 4 wire O2sensor(with heater). alot more than a single or double wire o2 sensor.
i was quoted $256 for a after market O2sensor from napa, but ican get one for $250 from OEM..
but make sure, get somebody to use OBDII on it first b4 repalcing
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
