disabling the EGR? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2003, 02:01 PM   #1 (permalink)
Senior Member
View Lychee's Photo Gallery
disabling the EGR?
Is there a way i can disable or block off my egr in my 1998 5sfe ???
1998 Camry LE -- Black
Mods -Osram Silverstars -14inch Alloy wheels -Short ram intake
2001 Camry XLE -- Silver Bone stock
Lychee is offline   Reply With Quote
Old 09-18-2003, 08:37 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
ummm....outta curiosity.....why would you want to do that???
HaHa
Old 09-18-2003, 08:52 PM   #3 (permalink)
View warlock's Photo Gallery
why?
warlock is offline   Reply With Quote
Old 09-18-2003, 11:55 PM   #4 (permalink)
*The SV-11 Driver*
idrivemyself's Avatar
View idrivemyself's Photo Gallery
this is probably a dumb question, but what the heck is an EGR and what exactly does it do? i ran a basic search for some insight, found next to nothing.
2001 GTI VR6
1986 Camry (SV-11)
idrivemyself is offline   Reply With Quote
Old 09-19-2003, 01:38 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
EGR = exhaust gas recirculation
It recirculates unburnt exhaust gases back into the intake manifold.
Damn smog / emissions equipment.
"Skoolin' the unlearned!"
Old 09-19-2003, 12:38 PM   #6 (permalink)
View SE V6's Photo Gallery
You can create a blocking plate out of aluminum, etc where the EGR meets the intake manifold. Most likely you will get an engine code though. And of course why you would want to block an EGR? To decrease the intake charge temp. Have you looked inside your intake manifold recently? Between the EGR and the breather hose from your valve cover, can you say dirty, oil coated mess and soot to boot.
Well, if you're looking for usable performance gains, there are more effective ways (ie. exhaust, CAI, etc.). The CEL may cause more problems than it's worth.
Good Luck!
SE V6
SE V6 is offline   Reply With Quote
Old 09-19-2003, 01:26 PM   #7 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
What you can do is disconnect the vaccuum lines that actuates the EGR valve. If you want to get rid of the engine light, you can always wire in a resistor that corresponds with the resistance that your ECU needs to think that the EGR is still working. For the Gen3 Camry, the resistance is 12k ohm.
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 09-19-2003, 01:39 PM   #8 (permalink)
*The SV-11 Driver*
no wonder i didn't have a clue about it... car ram-rod don't need no american-boy smog crap!
2001 GTI VR6
1986 Camry (SV-11)
Old 09-22-2003, 12:49 AM   #9 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
What you can do is just make a block off plate, and then put on a valve cover breather. Let the EGR just pump air through itself.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 09-22-2003, 11:44 PM   #10 (permalink)
I am just a newbie!
How would the valvecover breather have any connection with the EGR valve? The EGR valve picks up exhaust gases from the exhaust manifolds and it recirculates it back to the intake manifold. It lower combustion temperatures and reduces NOx emissions.
Installing a breather filter will not affect the EGR system in any way. If you install a block off plate, most likely the check engine light will light up because the EGR temperature sensor will not pick up any signals and might put the car in limp mode (in some generation Camry's).
Old 09-23-2003, 12:53 AM   #11 (permalink)
3s-fte power!
djprefix's Avatar
Oh, on my gen 2 there's a metal pipe that goes to the bottom of it and into the head. Or is that the pcv? * looks confused* Damn, I really need to get another camry, my brain's getting rusty.
Old 09-23-2003, 01:44 PM   #12 (permalink)
I am just a newbie!
Haha, yep, that is the PCV valve you are talking about there. The hose/pipe that comes from behind the engine block is the PCV as it recirculates oil vapours inside the crankcase back into the intake manifold.
The EGR has a metal pipe, about 3/4" in size and it is directly hooked up to the exhaust manifolds and also to the intake manifold. There is a vacuum regulator that controls the opening and closing of the valve to allow exhaust gas recirculation whenever it is needed.
Old 09-24-2003, 07:02 AM   #13 (permalink)
Grenaded piston
88 LE's Avatar
Oh, on my gen 2 there's a metal pipe that goes to the bottom of it and into the head. Or is that the pcv?[/B]
Your right about the egr. Theres a metal pipe that goes from the egr to the back of head (by cylinder #4).
Theres a pcv system on 3S-FE's, but no pcv valve. Just a hose from the valve cover to the throttle body.
Old 09-24-2003, 12:51 PM   #14 (permalink)
3s-fte power!
djprefix's Avatar
woohoo, I don't feel like a retard now!
