when do I need Fuel Injection Cleaning?? My camry has 110K miles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2003, 04:36 PM   #1 (permalink)
View Protocold's Photo Gallery
My camry has 110K miles and I saw a local pepboys will do a fuel injection cleaning for $69.
Should I do? What is it involved? What is the difference between that and those off-the-shelve fuel injector thingy that you pour into the gas tank???
Any advice will be appreciated. Thanks.
Protocold is offline   Reply With Quote
Old 09-22-2003, 06:16 PM   #2 (permalink)
Bump. Anyone?
Old 09-23-2003, 01:46 PM   #3 (permalink)
View haa21's Photo Gallery
There is a a big difference between the off the shelf stuff and a professional cleaning. If you have never had your injectors cleaned I would have your Toyota dealer (not Pep Boys) do a complete fuel injection cleaning. I'm sure your fuel filter needs to be replaced, too. Once that is done you can use the fuel injector cleaner stuff from the local autoparts store to keep your injectors clean. I use it every 4000 - 6000 miles.
haa21 is offline   Reply With Quote
Old 09-23-2003, 03:53 PM   #4 (permalink)
Should I get fuel filter replaced first or get fuel injection cleaned first????
I know a local mechanic that will change the fuel filter for me for $30 labor if I provide the parts.
Old 09-23-2003, 05:15 PM   #5 (permalink)
I would have it all done at the same time.
Old 09-23-2003, 06:38 PM   #6 (permalink)
Current title:
View Ikon's Photo Gallery
agreed. do everything at once. its kind of like replacing only one contact lens. with anything do everything at once. you might also want to check out ur timing belt too if that hasnt been done in a while.
Gen-3 Coupe '95 1MZ-FE
Custom Ram Intake w/K&N Filter
H & R Springs, Strut Bar,
Denso Plugs, Crappy 6 Spoke 16" Nissan rims w/kumho rubber (i got um for free ok?)
TRD Supercharger, Custom exhaust coming soon..maybe..hopefully..someone got some extra loot?
Ikon is offline   Reply With Quote
