98 camry I4 hesitation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 08:48 PM   #1 (permalink)
Defender of the Universe
View Miranthis's Photo Gallery
Question 98 camry I4 hesitation
I have a 98 camry I4. He body has 306K on it but the engine was rebuilt (sludge recall :-) ) at 237K so the engine has only 69K on it. I noticed that during acceleration I get an intermittent hesitation at about 2000 rpm or so. I also think I feel it form time to time on cruise control at highway speed, but that is not clear.
At first I though it was the tranny, given that it is original, but in test driving it the RPM's drop off when it happens, as opposed to going up - this makes me doubt the tranny is that cause. I seafoamed it both through the vac line and adding seafoam/cleaner to the tank to try to flush out any fuel system issues, but the hesitation remains. I am NOT getting any MIL/CEL codes thrown.
I am in the process of cleaning the car up to put it on the market as I got a new-to-me 2005 SE. Could this be an injector? Fuel pump, just bad gas/dirty tank etc?
Jeff
Miranthis is offline   Reply With Quote
Old 11-20-2007, 05:02 PM   #2 (permalink)
after a brief chat with my tech at the Dealer he advises that since it is not throwing a code to look at the MAF sensor, throttle body and possibly clogged injector(s). I am going to d/l the OBDII data with the long and short term lean info to see if can narrow it down. I will also do a TB cleaning and make sure to get the MAF included in that cleaning.
Any other bright ideas?
Jeff
Old 11-21-2007, 04:12 PM   #3 (permalink)
View marc780's Photo Gallery
I think you and your mechanic are on the right track so far, sounds strongly like an injector problem to me. At this point may i suggest you have the injectors removed from the engine and professionally cleaned or simply replace them - i'd compare the costs and you may just opt to replace them.
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Coolant loss 2005 Camry I4 winstead22 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-29-2007 05:07 AM
2007 Camry LE I4 Hesitation Problem Serviced CincyKid 5th & 6th Generation (2002-2006 & 2007-2011) 4 10-26-2006 10:59 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
98 camry 5FSE to 3SGTE S13/R32 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-09-2004 07:56 PM
