96 Camry LE Auto transmission problems
I have a 96 Camry - 4 cyl-LE Wagon with 99,800 miles that I bought new in 1996. I have had the AT transmission fluid replaced every 15,000-30,000 miles during the 11 years of owning it. After a long trip of 700 miles last summer, I noticed the AT did not want to shift up easily. It would hold in the lower gear and not want to shift easily. I had the AT fluid changed and it seemed to be better. Although it still shifts hard about 20% of the time. I notice if I let the AT shift at 2,500 rpms and below, it generally shifts smoothly. But if I start out from a stopped position and hold the accelerator down to maximize acceleration it will often hold in gear and/or shift hard. I do not use the "power" button on the AT. Last week I had the transmission changed again, and they found brass or metal filings in the bottom of the pan. The mechanic said the AT was failing and a new re-mfg transmission with oil cooler and all associated parts would cost $4,219 including labor and parts. The re-mfg AT would have a 12mo warranty or 12,000 miles. I do not know what to think about replacing the AT. I love my wagon and don't really like the new Toyotas as well as what I have now. My car looks and drives like new except for the AT sometimes shifting hard. Could there be some other reason, other than needing a new AT that I have this hard shifting problem?
doug
Reason: add 4 cylinder info
