All you have to do is remove all the black plastic clips from the radiator cover and then remove the screw that holds the corner lights in. Then remove the 2 screws on the top of the upper grill, and pull up to remove the upper gril. Then from there, just remove the 3 or 4 nuts that hold the headligh in place. I can't remember if it's 3 or 4, but its 1 behind the corner, 2 near the grill, and there might be 1 near the top on the fender. Then just pull it out, unplug all the connectors and then plug them in to the new headlight, and screw everything back together. Its really simple.
