knock sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2003, 08:07 PM   #1 (permalink)
View levarg's Photo Gallery
Question knock sensor
what is the resis. on the 3vz knock sensor. i belive the 1 mz is also the same. please help
3VZ FE TURBO
levarg is offline   Reply With Quote
Old 09-20-2003, 08:23 PM   #2 (permalink)
helppppppppppppppppppppp meeeeeeeeeeeeeeeeeeeee.
i need my boost back
3VZ FE TURBO
Old 09-21-2003, 12:26 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yo i checked it out in my FSMs and it says that the input to the ecu from KNK1 and KNK2 is a negative sourced reading but there is a resistor in the circuit with it. im not sure about the resistance, i believe it varies with engine speed. from what i see, it could possibly be the same as an oxygen sensor. if i were you i will attempt reading the resistance while the car is going without high boost, justfind the resistance that you need and work from there. it is definitely a negative reading though.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
