Better Acceleration In '99 Camry... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2003, 11:26 PM   #1 (permalink)
wvagravehunter's Avatar
View wvagravehunter's Photo Gallery
Okay, here it is, plain and simple. I was going down the interstate, and started off on the on-ramp and this little cavelier (sp?) took off and zoomed on by me while I was still trying to get mine to speed up there. I know that my Camry once had that kind of power, if not more, but now it don't. What can I do to fix this problem? Nothing pisses me off more than being passed up by some dumbass with a shittier car than I have...
'99 Toyota Camry LE
wvagravehunter is offline   Reply With Quote
Old 09-21-2003, 12:00 AM   #2 (permalink)
View JeffTsai's Photo Gallery
Its one out of three things:
1) A phsychological thing.
Depending on your mood, how much traffic there is, or what music you are listening to will make you car feel faster/slower.
Try this. After doing something fun or enjoyable go drive around listening to fast beat music and drive around where there arent too many cars on the road. Oh yea, best results at night since there is less traffic and because ....well just because =P. If you follow those procedures then you will feel that your car is faster!
However if you are pissed off about something bad that just happened and are stuck going thru a traffic ridden street then you will feel as if the motor got swapped with a civic enigne.
2) A weather thing.
Cars run faster in cold weather. Im not sure, but I think every 20F sum degrees the air pressure is 1psi denser so it equates to like a 4-5% increase in power. Also, DONT push the motor too hard in 20F (a bit below 0C??) weather like i did, or you will have a rod go thru your oil pan.
3) Maybe there is really something wrong with your car? When did you last change the motor oil. Go thru periodical maintenance procedures?
Most of the time if your car feels slower its because of #1,2 especially if your car is a 99 like mine is. However if you have a 1991 accord like my friend, the thing is so old that its obvious why the car is lacking power.
05' Lexus GS300 Crystal White
Electrical & Lighting: Custom M5 Bi-Xenon HID Retrofit (Done by me), HID Foglights 6000K, Optima Yellow Top
Suspension & Brakes: Tein Flex Coilovers, SupraTT 4pot Calipers, G-Stop SS Lines
Engine: L-Tuned Exhausts, SRT Intake
Boost in the summer 2JZ Power!
JeffTsai is offline   Reply With Quote
Old 09-21-2003, 06:14 AM   #3 (permalink)
Thanks man, that makes a good bit of sense. I was really hoping that there wasn't anything majorly wrong with my Camry, I keep up with the periodic maintenance and everything. Although it is due for an oil change within the next 100 mi. or so. So more than likely, I would say that it's a psychological thing though. But thanks again.
'99 Toyota Camry LE
