No, I know it is the master switch that is bad. When this happened many years ago I connected the power line directly to the motor and could move the motor. Then I left the switch and power to this window disconnected. The car had some work done after it was stolen and the shop must have hooked it back up.
Anyway, I checked the elctrical diagram and it looks like the blue (middle) wire is the hot line, so I think if I connect that to one prong of the plug from the window motor and ground the other prong it should work.
EDIT:
As I thought. The blue (middle) wire on the plug is the power. Connect that to one of the prongs on the motor plug and ground the other plug. This will move the window in one direction. Reverse the connections and the window moves in the other direction.
Reason: Figured it out.
