Wheel question again - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2003, 12:52 AM   #1 (permalink)
View fatrabbit's Photo Gallery
I know this question had been ask so many times already. But I did try to search the forum and got no results. Here's my question and hope u guys out there can give me an answer. Will a 16x6.5 wheel +50mm offset w/ 215/60/16 give me any problem on my 03 Cam? Thanks.
fatrabbit is offline   Reply With Quote
Old 09-22-2003, 03:30 AM   #2 (permalink)
Wheels Direct rep
soulibrium's Avatar
View soulibrium's Photo Gallery
yes, that wheel will fit your car. no, that tire will not fit the wheel. if your gonna run a 16x6.5 i would suggest a 205 width. if you want to run the 215/60/16 (wich i dunno if its the rite size for your car) would run a 7" wide wheel. BUT, you can sqeeze it if you want. since the side wall is soo tall, i believe there should be more "flex" so that tire can mount andhoold air. "should", but i recomend a 7" to be better off.
soulibrium is offline   Reply With Quote
