3s-gte camry time is near! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2003, 05:09 PM   #1 (permalink)
menaboy64's Avatar
View menaboy64's Photo Gallery
OK guys I have a shop near my house that can get me a jdm celica front end clip for about $2,300. I am going to get it soon and start with the swap. I will have everything from the car since it is a complete front clip but is their going to be anything else I will need to drop it into my 87 camry 5 speed? I know the celica is an all wheel drive so what should I do about that? Any advise and info about parts I will need will be GREATLY appreciated. Soon I will be king!
www.craptoons.com Oh it's true, it's damn true!
menaboy64 is offline   Reply With Quote
Old 09-22-2003, 05:25 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: 3s-gte camry time is near!
1. Covert the Camry to AWD.
2. Look for a MR2 Turbo clip instead of a Celica clip.
3. Use the motor from the Celica clip and get a tranny from MR2 Turbo.
4. Use the motor from the Celica clip and get a tranny from a Celica GT-S (3S-GE).
"Skoolin' the unlearned!"
Old 09-22-2003, 05:31 PM   #3 (permalink)
menaboy64's Avatar
Damn, I've been searching and I kinda figured that out but then I thought that with the celica even the axles would fit so I wouldn't have to look for other parts. I would buy the engine by itself but I need the clip for the ecu andf wiring. Hmmmm, this is going to take lots of donor parts. I have to find a gt-s for the tranny and a mr2 for the engine, ecu, and wiring. Would that work? Which tranny is better, the mr2 one with the different case so it will fit or the gt-s one? Are they just the same with different bellhousings?
Old 09-22-2003, 05:43 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yes, but don't forget about the sensors and ignition stuff.
Best bet is to find a MR2 Turbo clip.
You can use the tranny from the MR2 Turbo, but if I remember correctly you have to swap the housing for one from a Celica GT-S cos the shift linkage is on the wrong side.
I wonder if a E153 tranny from a Solara would bolt up to a 3S-GTE.
Which tranny is better, the mr2 one with the different case so it will fit or the gt-s one? Are they just the same with different bellhousings?[/B]
I believe that the gear ratios are different. Other then that I dunno.
Wraith would know for sure. Hes the man when it comes to info about 3S-GTE's.
Old 09-22-2003, 07:36 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Instead of using a E153 trans from a MR2 Turbo use the Solara one or even one from a V6 Camry. It will bolt up. Only thing is you would need cables from either Solara , Celica GTS or Camry V6 ... I found out I'm using 20valve cables thats why my throws are sooo much more shorter than the Solaras...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
