Exhaust and Intake options - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2003, 08:55 PM   #1 (permalink)
View jppaully's Photo Gallery
for a 3vz-fe v6 what intake should i get, and also i'm looking for a catback system, but i'm not exactly sure what the cat back is exactly, i know its new piping (wider) and muffler and exhaust tip, but does it completely get rid of the CAT or just start ther?
how thick should the piping be for the v6 3vz?
if the cat is supposed to stay, which i think so, is ther a high flow cat i can put in its place to help with air flow?
and what muffler/exhaust do you guys recommend?
thanks for your help
jppaully is offline   Reply With Quote
Old 09-22-2003, 09:11 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Re: Exhaust and Intake options
Cat back start at the cat and goes from there on. Hence the name "Cat-back". Intake and exaust choises are really a preference to the owner. And as for diameter, on a stock engine, V6, I would not go larger than 2.75" because a naturally aspirated engine needs some backpressure.
You can find different products for your car by doing a "search" located at the top of the page.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 09-22-2003, 11:53 PM   #3 (permalink)
The Oddity
Aussie Ed's Avatar
View Aussie Ed's Photo Gallery
I've gone for a 2 1/4" cat back on my auto v6 camry and its going good. I also have a replacement K and N pannel filter and that evens out the loss of bottom end which I've experienced after getting the car back
I was told to go no bigger than 2 1/4" for a cat back otherwise I'd lose heaps of bottom end.
It would also depend on your transmission type. You can go a little bigger to about 2.5" if its a manual, but auto I wouldn't recommend anything better than 2.25"
TN's Aussie Oddity, now with Evo 9 power??
Aussie Ed is offline   Reply With Quote
