Squeaking from rear 04-Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 09:13 AM   #1 (permalink)
Slemay
View Slemay's Photo Gallery
Gen5 Squeaking from rear 04-Camry
I have a 2004 toyota camry and I have eibach springs and a TRD rear sway bar (set up on the roughest setting) since may of 2006. I live in a pretty cold climate and since the cold has arrived I have a squeaking noise from the rear of the car. You can hear the noise with the smallest bump and even giving a quick jerk of the wheel. I've sprayed W-D40 and white grease on the springs/bushings and around the bushing of my sway bar. Did not help the situation. Does any have the same problem? Any ideas?
Slemay is offline   Reply With Quote
Old 12-06-2007, 02:15 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Remove the bushing from around the sway bar and lube it with synthetic grease. I've had great success with similar setups.
2006 Camry LE Special Edition
Old 12-06-2007, 02:30 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Don't use WD-40. Seriously, that stuff isn't really meant to be a lubricant or penetrating oil though lots of people seem to think it is.
Do as TRD VTi said. You need to take the bushing out and put some good grease on there.
2007 Camry 2.4L 5M
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
'92 Camry Rear Thumping Noise - PLEASE HELP ltat 3rd & 4th Generation (1992–1996 & 1997–2001) 5 12-26-2006 12:24 AM
Rear A/C on SE camry Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 5 10-03-2006 10:12 PM
