Fuel Filter Need Help Asap Pleaz - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2003, 01:50 PM   #1 (permalink)
View Kirill's Photo Gallery
Today i decided to change fuel filter .<
So i decided to losen at first the bolts.I untightend the bolt on the top but the bolt down the filter wont go.I can`t see this f***** shit any help
Kirill is offline   Reply With Quote
Old 09-24-2003, 03:48 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
eat your crusts, some spinich and giv'er shit
you can try to lock in another wrench to give more leverage, but i don't think there's room
lots of ppl seem to have problems with that bolt, but most of those ppl haven't changed their fuel filters in 5-10 years, they get what's coming to them
or you could bring it to the garage, its not a long job
-Nick
Nick is offline   Reply With Quote
Old 09-24-2003, 04:15 PM   #3 (permalink)
Here
View Velocity's Photo Gallery
I had the same problem and increasing the more torque to loosen it is not a good idea. I added more power to loosen it and it caused the threads on the lower portion of the FF to strip. Then I stuck and couldnt go any further nor backward because the thread was stripped causing gas to leak like a mofo so I had to cut the metal fuel line and replace it with fuel hoses, and fittings to the new FF. My suggestion would be to definatley use a flare wrench instead of a normal wrench or else you'll end up stripping the bolt. Also becareful of how much torque you apply or you'll end up having to cut the fuel line as i did.
Velocity is offline   Reply With Quote
Old 09-24-2003, 05:57 PM   #4 (permalink)
View wontonjohnny's Photo Gallery
whats a flare wrench????
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 09-24-2003, 06:01 PM   #5 (permalink)
Nick's Avatar
also called a line wrench, which is the "proper" tool to be using when working on any kind of fluid line
it grabs more corners so you won't strip the fitting, which is a pain in the arse to replace if you fuck it up
-Nick
Old 09-24-2003, 06:07 PM   #6 (permalink)
Nick's Avatar
-Nick
Old 09-24-2003, 06:12 PM   #7 (permalink)
arent the connections banjo?? .. couldnt you just use sockets???
5 speed 3vzfe - RIP
project F23 CL-T
Old 09-24-2003, 06:13 PM   #8 (permalink)
Nick's Avatar
explain banjo
-Nick
Old 09-24-2003, 06:18 PM   #9 (permalink)
banjo fittings...
bolt with a hollow core ... bolt goest through a ring also with a hollow section for fuel to enter the bolt
something liek that ... but it basically gets rid of inline hose connections...
5 speed 3vzfe - RIP
project F23 CL-T
Old 09-24-2003, 06:21 PM   #10 (permalink)
Nick's Avatar
oh yeah, the top one is, but i believe the bottom one is just a straight line out
but i'm not 100%, i'd go check but its pissing rain out
-Nick
Old 09-24-2003, 06:24 PM   #11 (permalink)
i think your right...
5 speed 3vzfe - RIP
project F23 CL-T
Old 09-24-2003, 06:25 PM   #12 (permalink)
did changing your filter do anything???
the guy at toyota said it shouldnt have to be changed if your car isnt lagging... and if you use good fuel. it should never need changing
5 speed 3vzfe - RIP
project F23 CL-T
Old 09-24-2003, 06:29 PM   #13 (permalink)
Nick's Avatar
haynes manual says to replace fuel filter every 30k miles (50k kms) or every 2 years
which i think is a good guideline, filters are dirt cheap and they're there to protect you, there's a lot of crap in gas
those old tanks they got under service stations have tons of sediment and rust flakes in there, most important of all, never fill where they just filled the tanks, it puts everything that was in the tank into suspension
and that primary filter in the tank dosen't do much
-Nick
Old 09-24-2003, 06:34 PM   #14 (permalink)
fuel filters arent cheap
65 bucks for toyota ... id suggest that you not use other brands like bosch ....
5 speed 3vzfe - RIP
project F23 CL-T
Old 09-24-2003, 06:54 PM   #15 (permalink)
Nick's Avatar
heh, i think you can get them for 30-40$ at crappy tire,
and its cheaper than continuously straining your fuel pump, and or messing up your injectors
-Nick
