Transmission fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2003, 08:10 PM   #1 (permalink)
View 94camryLE's Photo Gallery
Question Transmission fluid?
I recently bought the Z-Max Engine Power Treatment Kit and it comes with a formula for the transmission fluid. but i cant find where (in the engine compartment) to add it. Does any1 know where exactly is the transmission fluid located?
94camryLE is offline   Reply With Quote
Old 09-24-2003, 08:12 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
In the tranny. You have to get underneath the car to check the level. There are 2 bolts, one to check the level, and 1 to drain. When checking the level you should be able to put your finger into the bolt hole and feel the liquid level.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 09-24-2003, 08:13 PM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
In autos you fill through the tranny dipstick hole. In manuals there's a bolt mounted underneath the transmission to drain and a bolt on a vertical face to fill. I have no idea how you drain an auto. Presumably there's some kind of drain plug down there.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 09-24-2003, 08:15 PM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
right through the dipstick tube, just get a small funnel
-Nick
Nick is offline   Reply With Quote
Old 09-25-2003, 12:27 AM   #5 (permalink)
thanks alot, i never knew you could add into the dipstick hole
