dash board warning lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2007, 08:00 PM   #1 (permalink)
View icoben's Photo Gallery
4th Generation dash board warning lights
Im a newbie.
Got my first car 6 months ago. it is a 97 camry LE.
There is no warning light on when i got it.
But, on August when I changed the engine oil, there was only about one liter oil coming out, and pretty black oil~~.
I was so wondering why the oil pressure light didnt blink before.
I added about 1 gallon oil and checked the dip stick. It is just below full.
I checked the dash board, there is a good bulb in there.
only one question. Should the oil pressure light be on for a second or not when i start the engine??
icoben is offline   Reply With Quote
Old 12-09-2007, 02:06 PM   #2 (permalink)
Gameroom cash: $304355
"only one question. Should the oil pressure light be on for a second or not when i start the engine??"
Yes, it should come on for about 1 second when the engine is first started. The light indicates oil pressure, not volume of oil. When you first start the engine, the oil pressure must build up, via the oil pump, and pump oil to all parts of the engine, including where the oil pressure sensor is located.
As far as your experience of being previously extremely low on oil, the light will only come on when there is a severe pressure drop. The light has little to do with oil volume. The only time oil volume will trigger the light, is if the oil level falls so low that the oil pickup in the bottom of the oil pan can not reach the oil level to pick any oil up and pump it throughout the engine. If this happens, severe engine damage will occur within a couple of minutes. If you ever see the oil light come on, indicating a lack of oil pressure, stop the car immediately. I would also advise checking the oil level more frequently, about once a week for a while, until you determine the oil usuage of your engine in miles driven.
As a side note, on future threads, it is always advisable to list your engine size (4 cylinder or 6 cylinder is good enough) and the mileage on the vehicle, along with any known maintainance history of the car.
Mike
Old 12-09-2007, 06:50 PM   #3 (permalink)
Mike: thank you so much!
this is a 4 cylinder 140k miles camry.
I am the 8th owner, so not sure the previous maintance.
I have to check the oil pressure sensor right now.
How to change the dash lights? flamerid 3rd & 4th Generation (1992–1996 & 1997–2001) 10 11-07-2011 04:57 AM
Few dash lights are out on my 92 camry Le,helppp TheGhostCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-02-2006 09:24 AM
Dash Lights not working 2006 tacoma hartmang 2nd Generation (2005+) 5 03-07-2006 02:07 PM
Trouble with backup lights and dash shifter lights. camry1993 Camry & Solara Lounge 0 03-21-2005 09:24 PM
