95 Camry Shutters in Reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2007, 11:50 AM   #1 (permalink)
View Kans_Geo's Photo Gallery
My daughters 95 camry 2.2 engine automatic trans shutters when the car is put in reverse, worse when the temperature is cold. It also shutters when put in drive but not as bad. The car seems to idle fine when in park or nuetral. It seems like the problem is only at lower RPM and smooths out as the engine RPM increases. Is a transmission problem, or is it the load on the engine causing the it to run rough for whatever reason? Anyone else experienced a similar problem?? How do I troubleshoot??/ No check engine light.
Kans_Geo is offline   Reply With Quote
Old 12-13-2007, 12:21 AM   #2 (permalink)
View toyomoho's Photo Gallery
Try these post for ideas:
95 Camry Shutters in Reverse Kans_Geo Camry & Solara Lounge 2 12-10-2007 11:20 AM
New here, suspension questions on a '95 Camry Patman36 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-17-2004 02:28 PM
