Injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2003, 01:24 PM   #1 (permalink)
View luisitol's Photo Gallery
Injectors
Hey guys i was looking for as much possible info on the stock 5sfe Injectors.
I'm looking at upgrading the injectors but need to know stock specs, like flow rate, high/low impedance, and side/top feed. Thanx for the info guys.
Oh yea i know the MKIV NA Supra injectors fit, but i just want to have as many options as possible.
luisitol is offline   Reply With Quote
Old 09-26-2003, 01:38 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
search on yahoo or something and type in mr2 5sfe injectors. see what you come up with.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-27-2003, 11:03 AM   #3 (permalink)
Will the 7M-GTE 440cc Injectors work on the 5sfe? Those would a bitch to tune with the SAFC though
Old 09-27-2003, 05:38 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
im pretty sure thats been done...
Dave Zoni
Old 09-27-2003, 06:18 PM   #5 (permalink)
do you know who has used those and been able to tune them? The SAFC only tunes to +or- 50% so the largest that the safc will tune for accurately for the 5sfe sould be 420cc (210cc x 2)
Old 09-28-2003, 09:04 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
i dont know how the safc works, so i couldnt help ya out there... sorry
Dave Zoni
Old 09-29-2003, 12:17 PM   #7 (permalink)
how much boost should the MKIV Supra NA Injectors (310 cc suposedly about 360cc at our fuel pressure) be able to support?
Old 09-30-2003, 10:17 AM   #8 (permalink)
I'm a Mac
zoni's Avatar
10 psi ???????
Dave Zoni
Old 09-30-2003, 05:18 PM   #9 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
Boost is not equal for different turbos. Those injectors might handle 16 psi on a stock CT-26 for example, but would only handle less than 6 psi on a larger turbo. Each pound of boost will have completely different amount of airflow for small and large turbos.
If you want a good answer, you should have asked how much HP those injectors would handle instead. To find how much HP, you can always go to RCEngineering's website for injector flow rates and HP rates. They have a nice HP/flow rate caluator there.
http://www.rceng.com/technical.htm
The SAFC would only correct up to 420cc injectors (based on your calculations), but you can always run slightly lower fuel pressures to compensate for the extra 20cc/min of fuel so the car would idle properly
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 09-30-2003, 05:56 PM   #10 (permalink)
Tony, yea i realized that after i asked the question. I had totally forgoten about the RCeng worksheet
About the Fuel pressure....what do you think would be a good pressure to compensate for the extra 20cc?
