Turn Signals not working! Need help... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2003, 02:08 PM   #1 (permalink)
View TaylorSyn's Photo Gallery
I have a 89 camry wagon v6 LE
Recently when I went to turn on the turn signal it will not go on left or right, there is no click, or no light.
However when I turn my Hazard lights on they work!
I checked the interior fuse box on the drivers side bottom, there is a fuse marked for the turn signal its 7.5 amp. I checked it it looks fine, I even plugged in another 7.5 amp fuse to be sure.
Now out of curiosity I also pulled the fuse and turned on my hazards and they still worked. So I am rather confused here...
Any help is appreciated..
Thanks
- Taylor
TaylorSyn is offline   Reply With Quote
Old 09-27-2003, 11:33 AM   #2 (permalink)
Layd Customs
View InTeReX's Photo Gallery
Check both of your turn signal bulbs...they both might be burned out? I had one burned out up front and it made my back one (same side) hyper blink, to compensate for the burned out i guess?? and then the other front side burned out and neither worked then, no lights or clicks when i turned on the signals. Replaced the bulbs and Voila...worked like normal.
Hope this helps.
InTeReX is offline   Reply With Quote
Old 09-27-2003, 09:26 PM   #3 (permalink)
View oibone781's Photo Gallery
check your tailights, the tailights, corners and signals all run to the same fuse..
oibone781 is offline   Reply With Quote
Old 09-27-2003, 11:44 PM   #4 (permalink)
Layd Customs
yeah, my bad...i meant check ALL of your bulbs! Probably got two burned out, front or back somewhere if you checked the fuse and it was good.
Good Luck
