Inner Door Panel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2003, 03:18 PM   #1 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
Inner Door Panel
I'm stumpped. I'm trying to get the inner door panel off of the door so that I can get inside and hook up the power mirror cable to the new mirror. I've taken out all of the screws and plugs, but the only thing that is keeping the door panel on is the inside door latch and lock. I've looked around it, but cannot find any more plugs to pop out, nor are there any more screws. I'm trying to do this without breaking anything, but I've got to find some way of getting behind the panel and into the plastic watershield to reach the cable. if anyone has any ideas, let me know
P.S. There was a screw inside the latch, but even after it's been removed, the latch and lock part will not budge.
Pete
1999 Toyota Camry 1MZ-FE 5spd
BigPete is offline   Reply With Quote
Old 09-25-2003, 03:47 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
If I remember correctly, you have to pull on it the same way you would as if you were opening the door and slide the backing foward (towards the front of the car). After you get that off you have to pull the door panel up to get it off the clips on the bottom of the panel.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 09-25-2003, 04:30 PM   #3 (permalink)
BigPete's Avatar
I had to pry the handle cover over a small bump on the top and bottom of the door. I finally got it, but I was just getting frustrated, so I thought I'd see if anyone on here knew what I was talking about
Old 12-24-2003, 11:35 AM   #4 (permalink)
View markisbond's Photo Gallery
All you did was pry it off? Nothing broke at all?
markisbond is offline   Reply With Quote
Old 12-24-2003, 12:38 PM   #5 (permalink)
rayray's Avatar
View rayray's Photo Gallery
don't know if the Gen4's are like my Gen3 but check out my front speaker installation. it should be fairly similar to get the door panel off.
http://rayrayonline.bravehost.com/frontspeaker1.htm
-rayray
rayray is offline   Reply With Quote
Old 12-24-2003, 01:02 PM   #6 (permalink)
I found out how..there are two clips on top and bottom of the door latch plastic thing...just get those two unhooked...it was a pain in the ass.... Finally got it off though and fixed.
Old 12-25-2003, 12:13 AM   #7 (permalink)
BigPete's Avatar
^^^^bingo. It's easy once you know what you're looking for.
Old 02-15-2004, 04:38 PM   #8 (permalink)
View clutterking's Photo Gallery
-rayray
rayray you really make passing that wire through the gromet look way too easy. I lost count how many hours I spent trying to do that and I just gave up... tomorrow is another day.
clutterking is offline   Reply With Quote
Old 02-16-2004, 08:56 PM   #9 (permalink)
rayray's Avatar
you can actually make it easier by cutting the rubber boot that runs inbetween the door and the jam. that way you can work the wire through in 2 steps instead of one difficult step. then just tape up the boot after.
-rayray
Old 02-16-2004, 09:44 PM   #10 (permalink)
Thats exactly what I was planning on doing, trying to do it all in one step is insanity, now I just have to wait for the weather to cooperate. btw, what was toyota thinking when they made it so you need to take apart the whole door just to replace a speaker?
you have a great site by the way
Old 02-19-2004, 12:26 AM   #11 (permalink)
rayray's Avatar
thanks man... it's been getting a lot of hits lately. even exceeded the bandwidth limit on Monday.... who woulda thought?!
-rayray
