Help with steering fluid loss 1994 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2007, 08:17 PM   #1 (permalink)
View olatou's Photo Gallery
Angry Help with steering fluid loss 1994 Camry
I just got a 1994 Toyota Camry, it's losing power steering fluid and my mechanic says he can't find a leak. Any suggestions
I'm not even sure I'm in the right forum.
olatou is offline   Reply With Quote
Old 12-21-2007, 11:43 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Squeeze the bellows at the end of steering rack and see if the fluid is coming out.
One of my customers had such leak on the REBUILD rack & pinion assembly of his 91 Camry v6.
Doctor J is offline   Reply With Quote
Old 12-21-2007, 01:59 PM   #3 (permalink)
View marc780's Photo Gallery
Get another mechanic, or try and find the leak yourself. Clean the engine bay and all the p/s hardware - the pump, the hoses and connections, including underneath - and look for the leak.
I find simple green works well forthis, the more you spray on, the better. Scrub off any left over dirt and do it twice if you have to- just get it clean as possible. THEN look for the leak. Probably locations - at any and all connections, power steering pump, rack seals.
Old 01-30-2008, 08:08 PM   #4 (permalink)
View bos_taco's Photo Gallery
Lightbulb leak help
one unusual place to look is on the the fan motor. my 94 with the v6 has a hydraulic motor running the fan on the radiator. that hydraulic motor is connected to the power steering pump. a leak there could cause power steering fluid loss.. hope that helps
bos_taco is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 07:34 PM
1994 camry DX loose steering karl_karl 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-17-2007 10:16 PM
Toyota Camry Remains America's Best-Selling Passenger Car humanoid Toyota News 0 10-06-2007 03:04 PM
1994 Toyota Camry LE Steering Question kc3k7 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-27-2006 07:06 PM
