Hey Racerhex, my TB was basically bored to the largest size possible. The throttle plate must be machined to perfect clearances... that's the main concern. A lighter plate will do nothing, unless you have such a weak left foot that you can't even crack open a throttlebody
You are better off changing to a lighter retracting spring if you want a lighter throttle feel.
Other than that, everything should bolt-up just like a stock throttlebody. The TPS will have no change at all, and everything will work like stock.
You are more likely to gain engine response rather than overall power after a throttlebody upgrade. This increase in engine response will help your engine accelerate faster between shifts or during sudden mash of the gas pedal --> faster acceleration times
Don't expect too much though because your motor is still relatively stock.
Anyway, taking out 400 lbs out of the Camry will put it to 2500-2600 lbs... That would be quite hard to achieve. A 2500 lb weight is the weight of an EK Civic hatchback and lighter than an Integra Type-R, and that isn't going to happen with a 4 door midsized Camry and a V6 motor.
Weight reduction is very simple at its initial stages.... spare tire, seats, unnecessary items and tools, and basic bolt-one (intake pipe vs stock intake and junk, lighter exhaust manifolds vs stock cast steel, etc...) Those are the easy 100-150 lbs and you can definitely feel a difference in all categories -- acceleration, traction, braking and steering response.
Next step would be gutting the sound deadening. Afterwards, it will be interior -- remving door panels, sound system (speakers), and interior panels. Those are the harder, but still free 50-60 lb weight saving.
All the above items are roughly 200-250 lbs or so. After shedding those easy pounds from the items above, there isn't really much left. In my opinion, stripping 400 lbs off the Camry isn't possible unless you get into lightweight parts -- lexan windows, lightweight seat, forged wheels, no side impact beams, and bumper reinforcement. etc... But after removing those safety components, you will need a rollcage, which adds 120-200 lbs back into the equation. It's not easy stripping big chunks of weight, and 400 lbs is A LOT for a 3000 lb car to start with!
