Check Oil Light On, But I Don't Need An Oil Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2007, 01:42 AM   #1 (permalink)
92 Camry DLX V6
View chuloloco's Photo Gallery
3rd Generation Check Oil Light On, But I Don't Need An Oil Change
Today out of nowhere my check oil light came up on my 92 Cam V6. I don't need to change my oil for another 1,200 miles. This may have something to do with it but right before the light came on I pressed the ECT Power button when I was trying to pass this Jeep, which I did by the way! I accelerated fairly hard for about 10-15 secs and my speed only hit 70mph for a brief moment. Then I brought it down to a steady pace.
The only other thing that might have something to do with it would maybe be that its been raining a lot here in MD. I say this because whenever it rains my car fairly frequently idles hard, vibrates when I accelerate like it kind of hiccups (as my foot is on the accelerator the car gives some gas but gives none then quickly gives gas and does this several time), and spews white smoke out my exhuast.
Maybe a combo of the 2 above caused my problem??? I will check tomorrow to see if the light is still on. If its not then I will let you guys know by posting a reply.
Thanks.
I SPIT IN THE FACE OF PEOPLE WHO DON'T WANT TO BE COOL!
chuloloco is offline   Reply With Quote
Old 12-13-2007, 01:57 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
ummm....time to check your oil. the oil light doesn't usually come on until the oil pressure is really low- to the point where you only have a bout half a quart/liter left, which means if you keep driving the car, engine damage will occur
HaHa
Old 12-13-2007, 03:51 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $911027
iTrader Score: 59 reviews
Yes, CHECK UR OIL LEVEL!!!(u might buy a couple of quarts before u do)
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 12-13-2007, 12:14 PM   #4 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Thanks.
I am very happy you passed that Jeep!!!
Very interesting fact about your weather!!!
CHECK YOUR OIL LEVEL IMMEDIATELY!!
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 12-13-2007, 12:44 PM   #5 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
Thanks.
Accelerating hard to 70 is nothing, try doubling that. As the others said, check your oil level. I'm betting it's a bit low...
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 12-13-2007, 08:38 PM   #6 (permalink)
92 Camry DLX V6
3rd Generation
Hey guys! Thanks for all your replys. My oil was low. REALLY low. Now I'm good. Just out of curiousity, I have about 1,000miles till my next oil change. So how many quarts do you think I will need to hold me over till then?
Thanks.
Old 12-13-2007, 09:46 PM   #7 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Thanks.
Just keep adding it until it's in between the full and low marks on the dipstick. Oil is cheap, much cheaper then repairing an engine due to lack of oil.
geoff5093 is offline   Reply With Quote
Old 12-13-2007, 10:28 PM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
always chek your oil....
if that light comes on its always bad news
make sure your oil filter/ drainplug are tight first of all....if not u could have leaking rear main seals, oil pan gasket or valve cover gaskets or you could be burning oil, which white smoke implies you might be burning oil or even have a blown head gasket....id say its time to take that camry to someone for a check up...
The "Executive Sedan"
Old 12-19-2007, 12:05 PM   #9 (permalink)
View Kingdom934's Photo Gallery
Blown head gaskets will often times leave a chocolate milk shake color goo on the underside of the oil cap, so you might want to check that.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 12-19-2007, 12:38 PM   #10 (permalink)
92 Camry DLX V6
3rd Generation
Where's the oil cap located? I have a 3vz-fe engine. Please use terms that are easily understandable as I am not extremely car savy under the hood.
Thanks
Old 12-19-2007, 02:39 PM   #11 (permalink)
2004 Camry LE
somick's Avatar
chuloco, you better take your car to a mechanic ASAP, before it is too late!
Good luck,
Sam
1992 Subaru Loyale
Old 12-20-2007, 04:23 AM   #12 (permalink)
engineer in training
Gameroom cash: $145055
The stuttering issue sounds like a classic cap and rotor problem, my 92 v6 will do that if moisture gets in the distributor, smoke out the exhaust and all. Ask the mechanic to check the valve cover seals, the rear is a trouble maker as far as oil leaks are concerned.
Old 12-20-2007, 12:07 PM   #13 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
You say you topped off your oil and all seems good now.
The oil cap is simply what you unscrewed from the engine head to pour in your oil. If you take it off and check underneath it, it's usually a good sneak peek of what is going on inside the engine. An insane amount of crud would indicate possible sludge (Just an example), in your case if you're worried about a head gasket, just look for milkshake-like goo under the cap, that would indicate coolant mixed in your oil.
Or else, unscrew the cap, take a closeup picture and post it here
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 12-20-2007, 04:29 PM   #14 (permalink)
Gameroom cash: $304355
"just look for milkshake-like goo under the cap, that would indicate coolant mixed in your oil."
It could also simply indicate moisture built up by a lot of short trip driving.
Mike
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
99 Camry-Leaking oil after oil change mailzz2000 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-12-2007 06:05 PM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 08:44 AM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
