MSD Ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2003, 12:56 PM   #1 (permalink)
View luisitol's Photo Gallery
MSD Ignition
Is the MSD 6A the same as the MSD 6BTM? I saw an item for sale that said MSD 6BTM, but the box said MSD 6A
luisitol is offline   Reply With Quote
Old 09-28-2003, 01:39 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
2 different boxes.
MSD 6BTM has a seperate box for retarding the igntion timing based on boost. BTM = boost timing master
6A is just a ignition amplifier.
http://www.msdignition.com
"Skoolin' the unlearned!"
Old 09-28-2003, 11:04 PM   #3 (permalink)
can the boost timing maching be added to the MSD 6A?
Old 09-29-2003, 01:54 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yes.
You can buy just the BTM box by itself.
http://www.msdignition.com/tc_18.htm
http://www.msdignition.com/tc_19.htm
Old 09-29-2003, 08:53 AM   #5 (permalink)
Thanx for the info again. What plug wires did you go with 88LE?
Old 09-29-2003, 10:33 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
Stock Toyota wires and dist. cap. You can't seperate the plug wires from the dist. cap on a 3S-FE.
I modified the dist. cap for a post so that I could use a external coil (MSD Blaster SS).
Pics:
http://www.imagestation.com/album/?id=4289847013
Old 09-29-2003, 11:50 AM   #7 (permalink)
is the same modification needed on a 5sfe? Do the stock wires perform well enough for your higher powere/ spark demand?
Old 09-29-2003, 12:58 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Well yes and no.
5S-FE have a external coil. Some gen 3 Camry's with a 5S-FE have a internal coil, but thats mostly Camry's in other countries.
You can use the stock coil with a MSD box or replace it with a aftermarket coil.
The distributor cap has a plugin for the wire from the coil. What you do is buy a MSD coil wire and it'll come with a post. You shove that post into the plugin on the dist. cap and seal around it with silicone.
The part you need is MSD 8403 (8mm wire) or 84039 (8.5mm wire):
http://store.summitracing.com/partde...art=MSD%2D8403
http://store.summitracing.com/partde...rt=MSD%2D84039
Works just fine.
Old 09-29-2003, 01:52 PM   #9 (permalink)
ok jsut want to make sure i've got it all b4 i start buying parts, i appreciate the info.
So if i keep the stock coils, i can purchase the smd wires and not have to make any modification to them right? Or do i have to covert the ends from female to male?
Thanx again 88LE
Old 09-29-2003, 02:05 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
If you keep the the stock coil you don't need to mess with the wire from the dist. cap to the coil.
You just pull the plug (has 2 wires) on top of the coil so that the stock ignition system no longer charges it and use the wires from the MSD box instead.
Old 06-08-2004, 05:33 AM   #11 (permalink)
almc2242's Avatar
View almc2242's Photo Gallery
88 LE I think you are my salvation. I have a 1997 3SFE engine Toyota RAV4. They came with distributer and external coil. I have the following parts;
1. MSD 6A
2. SS Blaster Coil 8207
3. Tach Adapter 8910EIS
4. HEI Coil Wire Blaster 2, Super Cond. [84039]
How do I hook all these parts together? I've tried MSD web site but they give a very general idea and no concrete info. Almost all is base on Honda. . Is their a diagram or some where on the net that I can go for for installation? Can you draw me a diagram, if it ain't too much trouble? Help, it has been more then a year since I've been looking for answers.
almc2242 is offline   Reply With Quote
Old 06-08-2004, 12:37 PM   #12 (permalink)
Gameroom cash: $147537
If you look closely at the wire diagram from MSD, you see a universial one. Also all the wiring on the MSD is the same, only thing different is the wire color on the stock plug. Basically you install the MSD box between the coil and stock ignitor. It means cut the wire to stock coil and connect the box in between. Of course you have to connect power and the adaptor according to MSD instruction. You'll need to find ground wire on the stock coil plug, can't mess it up.
Old 06-08-2004, 06:09 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
MSD box
Big red wire: +12V (connect it to the battery)
Big black wire: ground (connect it to the battery or bare metal surface in the engine bay)
Orange wire: Coil + (positive)
Black wire: Coil - (negative)
Both (orange and black) goto your new coil.
Red wire: + (positive) from stock coil
White wire: Not used. Tape off or heatshrink the connector on the end of this wire.
Tach adapter (MSD 8910-EIS)
Black wire: - (negative) from stock coil
Black plug with green and purple wire: Hook it up to the plug on the MSD box. You might have to use the extension harness that comes with the MSD depending on where you mount the tach adapter.
How to hookup the coil
Theres a plug that goes into the top of the stock coil that contains 2 wires. You need to find out which wire is positive and negative.
After you find out which wire is which, unplug it. Connect the positive wire to the red wire on the MSD and to the red wire on the tach adapter. Connect the negative wire to the black wire on the tach adapter.
Disconnect the stock coil wire. It goes from the stock coil to the distributor cap.
Shove the post that comes with the MSD coil wire into the hole (where the stock coil wire was) on the distributor cap and silicone around it.
Connect the MSD coil wire to the distributor cap and your new coil.
Hookup your new coil (orange and black wire from MSD).
How to test the MSD
1. Disconnect the end of the coil wire going to the distributor cap. Place the end of this wire near any bare metal surface in the engine bay.
2. Unplug the tach adapter. The black plug with the purple and green wire.
3. Turn on the ignition, but don't start the car.
4. Short the purple and green wire on the MSD with a piece of wire (strip off the ends of the wire).
5. When you remove the wire you should see a spark come out the end of the coil wire.
Old 06-08-2004, 06:45 PM   #14 (permalink)
STICKIE!!!!!
Great Info man
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
Old 06-08-2004, 07:28 PM   #15 (permalink)
Grenaded piston
88 LE's Avatar
^ Done.
I added on to the sticky in the hardcore/tech section.
http://www.toyotanation.com/forum/t17918.html
I'll draw up a diagram in alittle bit and post it up.
