Originally posted by luisitol
I read that there are some issues with fittin the 3SGTE actuator in the 5SFE engine bay. Is this true? If so what modifications have to be made?
The wastegate actuator (wga) hits the block and prevents the turbo from bolting on. What you can do is cut off some of the metal from the mounting bracket for the wga then weld it back together. This might or might not work, I haven't tried it so I couldn't tell you.
Or you can try bolting the turbo to the manifold so that the compressor is on the left and the turbine is on the right. This places the wga towards the radiator instead of the block.
If you've had to go to an aftermarket wastegate, which has shown good results?
I'd go with HKS or Tial.
