it might be easier to just use the connections on the stock combination meter (instrument cluster), even though they come from the ECU anyways... 0
Tach should be the black wire on the longest connector which i think is white.
Speed should be the Violet with yellow striped wire on the middle sized connector, which i believe is blue.
im not sure about polarity on these, you will have to test each one with a multimeter to check that out.
if you want to take them from the ecu, they should be the same colored wires on connector D with that is sized 11x2 pins. Those wires are right next to each other on that plug.
