Camry Transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2003, 12:36 PM   #1 (permalink)
View kaizoo's Photo Gallery
Post Camry Transmission
I had asked this question earlier and may be I wasn't very clear.
I would like to know when you change the transmission fluid on a 95 camry how many qts do add after the fluid has drained out. The book say 4.7qts for a drain and refill. It seems to be too much. Can any you guys tell me how many qts you add when you drain the transmission.
Thanks!
kaizoo is offline   Reply With Quote
Old 10-02-2003, 12:40 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
knowing if your talking about an Automatic or Manual transmission would help....
ratko.org
Ratko is offline   Reply With Quote
Old 10-02-2003, 01:40 PM   #3 (permalink)
Sorry. I have a A/T.
Old 10-02-2003, 03:07 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
the book i am looking at says 3.7qts... any chance you read the 3 wrong?
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 10-02-2003, 09:28 PM   #5 (permalink)
it was all a dream
Zoni's info sounds right. 4.9 qts sound like manual transmission specs to me.
ratko.org
Old 10-03-2003, 10:38 AM   #6 (permalink)
o.k. guys, I checked the owners manual and it does say 4.7qts for a 5s-fe engine and 3.3qts for v6 engine for A/T.
Old 10-03-2003, 11:47 AM   #7 (permalink)
View Truthunter's Photo Gallery
From 1996 Toyota Camry Factory Service Manual:
2.2L 4CYL
Drain and fill = 2.6 Qts
Dry-fill = 5.9 Qts
3.0L V6
Drain and fill = 3.7 Qts
Dry- fill = 7.1 Qts
Drain bolt torque = 36 Ft. Lbs.
Pan bolt torque = 43 In. Lbs.
Strainer bolt torque = 89 In. Lbs. for 4CYL, 97 In. Lbs. for V6
If your car has never had a trans flush, it may be a good idea to do it soon. See my recent post for procedure.
Peace.
Truthunter is offline   Reply With Quote
Old 10-03-2003, 12:30 PM   #8 (permalink)
The Oddity
Aussie Ed's Avatar
View Aussie Ed's Photo Gallery
how often should a tranny (transmission) fluid flush be done??
TN's Aussie Oddity, now with Evo 9 power??
Aussie Ed is offline   Reply With Quote
Old 10-03-2003, 12:42 PM   #9 (permalink)
Owner's manual do not mention anything about flushes. When you drain and refill your only replacing about 3/8ths of the fluid. The rest of the old fluid stays in the torque converter and cooler. So, flushing will replace all the fluid. I recommend a flush every 4 years or 60k miles.
Old 10-03-2003, 12:47 PM   #10 (permalink)
Thanks guys. I will drain and add 2.6 qts and then check the level.
Thanks again to all of you!
Old 10-05-2003, 11:48 AM   #11 (permalink)
The Oddity
Aussie Ed's Avatar
ok, cool.
