Engine Reuild; need tor bore it out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2003, 04:40 PM   #1 (permalink)
Oomp loompa doopidy doo..
spills1969's Avatar
View spills1969's Photo Gallery
OK, well the 3SFE is actin up, and I'm thinkin bout rebuildin the whole thing. So the question is do I need to have the block bored out before i put in new pistons and rings? Is it like turning your rotors (you need to do it every once in a while), or is mainly for performance gains? And if I get it bored out, dont I have to get speciality piston rings to make up for the bigger stroke?
http://www.cardomain.com/id/manwhorecamry
Nitrous is like a hot woman with STDs. You wanna hit it, but you're scared of the consequences...
spills1969 is offline   Reply With Quote
Old 10-02-2003, 05:00 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Engine Reuild; need tor bore it out?
Originally posted by spills1969
[B]OK, well the 3SFE is actin up, and I'm thinkin bout rebuildin the whole thing. So the question is do I need to have the block bored out before i put in new pistons and rings?
If the cylinder walls are in good condition you can just have it honed.
Are you going with oversize pistons? If so then yeah the block will need to bored.
Boring and honing is 2 different things. Boring increases the size (bore) of the cylinder.
Honing removes the glaze on the cylinder walls and gives it a nice cross hatch pattern.
Boring changes the size of the cylinder bore not the stroke.
If you bore out the block you need larger pistons.
"Skoolin' the unlearned!"
Old 10-02-2003, 06:53 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
Oh after you strip down the block (remove everything from it so you have just the block) take it to a machine shop / engine builder.
Have them checkout the block and measure the bore on the cylinders. They'll be able to tell you if you can just have it honed or if it needs to be bored.
