camry 91 V6 LE transmission info required - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2008, 11:59 PM   #1 (permalink)
View faizuk's Photo Gallery
Hi
I am new to TN , i have 91 v6 camry with 146 k , US model, sometimes a light pops in transmission display area as "NORM" , does any one has any info about this light and its function .Since it does not comes often or with out any special driving shift .
regards
khan
faizuk is offline   Reply With Quote
Old 01-09-2008, 02:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
The transmission has two shift pattern modes, NORM and PWR. The PWR mode moves the shift points up a little higher.
There should be a push button switch on the side of the shift console to select the pattern desired. When in the PWR mode the PWR light is on. From the wiring diagram the NORM mode also has a light. Not sure why it acts this way.
Old 01-10-2008, 10:28 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Yeah, just look for the button beside your parking brake lever that says "ECT". Push it to switch between better fuel economy (NORM) and quicker acceleration (PWR) by virtue of much higher shift points.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
so i crunched some numbers, true carlo$ 5th & 6th Generation (2002-2006 & 2007-2011) 36 10-28-2007 06:12 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2002 Camry LE V6 Timing Belt/Water Pump Replacement Info 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 13 04-06-2007 09:35 AM
