Dealer service blows! Timing cover loose... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2003, 02:07 PM   #1 (permalink)
threedom's Avatar
View threedom's Photo Gallery
The upper timing belt cover almost came off our car. The gasket was getting wrapped up in the timing gears. I noticed it when I went to change spark plugs, rotor and cap. Well, they don't even carry the bolt or the gasket and said basically, tough noogies!
I was able to get a 6x1x25 bolt @ Home Depot and reuse the gasket. I don't think I will ever have someone service our car unless it's a last resort, and I will plan on finding a good indy rather than utilizing the hacks at our local dealer.
They also told us that there's no differential to put fluid into, because it's a front wheel drive car, even though the owner's manual said to change it. It really steams my clams!
1995 Toyota Camry LE
Silverleaf Metallic
36k miles
KYB GR-2 struts
Goodridge SS brake lines
Hella Micro DE foglights
threedom is offline   Reply With Quote
Old 10-03-2003, 03:26 PM   #2 (permalink)
Official TN Rice Hater
97KaMuRi's Avatar
View 97KaMuRi's Photo Gallery
Re: Dealer service blows! Timing cover loose...
dude that sucks man.
My Prelude
i have left the toyota family but will return soon enough
97KaMuRi is offline   Reply With Quote
Old 10-03-2003, 03:39 PM   #3 (permalink)
View denuder's Photo Gallery
Who is your local dealer? Toyota of Durham or Fred Anderson?
denuder is offline   Reply With Quote
Old 10-03-2003, 04:42 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Damn.
WTF?
They can order the parts.
F**king idiots.
If that was the case they might as well get rid of the tranny and bolt the axles straight to the crankshaft.
Even my 1/8 scale r/c car has a differential. 3 to be exact.
"Skoolin' the unlearned!"
Old 10-03-2003, 05:23 PM   #5 (permalink)
threedom's Avatar
Toyota of Durham.
Sure they said they could order the parts, but I didn't want to wait, it was a simple low torque screw and the gasket wasn't too bad, it's only a dust shield type gasket. Anyway, it's been uncovered for I don't know how long, I mean you could look down and see the timing belt. One screw was very loose and one gone.
Ok, to be fair to them it was 3 years since they did the work, but the car had only 21k miles then and now it only has 36k. It has been my wife's car since it had 17 miles, way before we met. She never took it anywhere but that dealer for anything except tires. I don't think it should have came loose regardless of the time.
I plan on doing everything myself if at all possible.
BTW, Where do I get the factory service manual?
Silverleaf Metallic
36k miles
KYB GR-2 struts
Old 10-03-2003, 06:22 PM   #6 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Do you have a 5sfe? and if so...is it auto? (at least thats what i'm presuming) I know the differential and the tranny have their own drains...but the dealers refill those with ATF...Ie. UNLESS you have a m/t...then the linkage is not the same (duh!!).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 10-03-2003, 07:17 PM   #7 (permalink)
threedom's Avatar
I have a four cylinder automatic.
Silverleaf Metallic
36k miles
KYB GR-2 struts
Old 10-04-2003, 11:49 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
You can get them from the dealership or through some 1-800 number.
I don't know what the number is, but its been posted on this forum so doing a search should find it.
